Is my flywheel too much?
Old Oct 12, 2005 | 10:48 AM
Loony's Avatar
I got the big steel flywheel with my Street Twin and was wondering if it's too big(heavy) for a bolt on car? Will I be leaving a lot on the table? Most likely I'm going to run stock sized DR's through a stock 10 bolt...maybe slightly modded.
So do you think the flywheel is gonna suck up too much power? Should I go with a lighter one? Thanks!
Old Oct 12, 2005 | 02:48 PM
OBE1 95Z28's Avatar
Re: Is my flywheel too much?
You don't loose HP with a heavier flywheel, it "stores" the energy. The penality is that it takes a bit longer to rev up the flywheel, therefore road race guys don't like them. For drag racing, the stored energy will help prevent bogging off the line as the flywheel's interia will help keep it spinning when the clutch is engaged.
Old Oct 13, 2005 | 10:51 AM
Loony's Avatar
Which would make perfect since if I were using slicks correct? But if I'm using a stock sized drag radial on a 10-Bolt would that inertia really help me more than it would hurt me?
Old Oct 13, 2005 | 02:19 PM
OBE1 95Z28's Avatar
If you road race, it will hurt you, if you drag race it can help you. If you hardly race, it will probably hurt you. Your choice.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
