Changed my gears to 3.73 what should the RPMs be?
I have 1994 Z28 with LT1 and the A4 automatic, what kind of RPMs should I be seeing @75MPH with 3.73 gears? I'm now seeing 3000RPM . The car seems to be screaming now, like it used to @90+MPH.
Re: Changed my gears to 3.73 what should the RPMs be?
what would the RPMs be if the tranny was still in 3rd gear @75MPH and not in OD? Would that explain the High RPM's? last shif point seems to be about 50MPH
Originally Posted by Injuneer
My handy calculator shows, in O/D with a stock tire diameter, at 75mph:
3.73 - 2,550rpm
4.10 - 2,800rpm
3.73 - 2,550rpm
4.10 - 2,800rpm
The 700R4 has the same gear ratio as the 4L60E.
If you are seeing 3000 RPM, then you are probably not locking up the torque converter or getting it into overdrive.
Ok so I used the Tuner Cat program today to fix the speedometer, which it did, changed the fuel cutoff speed up as well, but now the engine is revving a lot higher. Didn't knowingly change anything else, is there something that I should change that would fix the OD not kicking in? This is turning into an adventure.
Originally Posted by bow94z
Do u take notice to see if it shifted into overdrive?
