Troubles getting into 6th
Old Oct 16, 2005 | 11:40 AM
LastOfBreed's Avatar
Lately I've been having problems getting my M6 to go into 6th gear. I pull it down into place and it vibrates and pops out. The only way to get it in is to literally slam it in and sometimes that doesn't even work. It never really grinds going in either.
Do I have some messed up synchros? Bad shift fork or shift rail? What's the problem here folks? Very rarely, but I also have problems getting it into reverse too.
Thanks for the help fellas.
Old Oct 17, 2005 | 07:03 PM
Re: Troubles getting into 6th
Anybody?
Old Mar 29, 2006 | 07:08 PM
HELP!! It's spring and I want my 6th gear back!!
Old Mar 29, 2006 | 09:45 PM
95LT1conv's Avatar
if you read a repair manual it will tell you that if you cant go in and out of reverse smoothly, then there is clutch pp component failure
Old Mar 30, 2006 | 12:55 PM
It's got a new clutch and reverse doesn't seem to be a problem anymore. It goes in just fine. However, I still have problems with 6th gear. It grinds a little when letting the clutch out when it hasn't fully engaged.
Ericksd
Jan 20, 2016 06:07 PM
brothaslide
Jan 9, 2016 12:11 PM
Schul365
Aug 22, 2015 10:00 AM
cmsmith
Aug 17, 2015 06:50 PM
