anyone gone from 3.23 to 3.42?
Re: anyone gone from 3.23 to 3.42?
Your RPM and your rear wheel torque will increase by 5.8%. Doesn't seem like a whole lot, but you should be able to feel it. Currently you should be about at about 2,075rpm at 70mph in O/D. The rpm will increase to 2,200.
i went from 3:23 to 3:73 to 3:42. didnt really notice much change on the first swap, but i never had an equal field to judge as i never got traction with the stock gears. but for the amount of highway driving i was doing the 3:73 turned more rpm's then i liked. so i went with 3:42. they do tons better on daily driving, but have not been to the track yet. as far as SOP testing i didnt notice much change in the 3:23 and 3:73, as i had spinning problem with both. but with the 3:42's they feel possibly a little bit slower off the line, but not really noticable. but the car is in the power range a little bit longer and actually feels a bit quicker in the mid range, like passing gear and such.
to sum all this up, if you dont mind running 2500 rpm at 70 and have sticky tires then 3:73 are cool, if you want a good middle of the road gear 3:42 are cool. you get a little more kick on the line and you can still run 75 or 80 without winding your car up to 3000+ rpm. i never really noticed milage differance in any of them. but then again with the cam i have if i go any higher gear i will get a ton of surge at hwy speeds.
Originally Posted by Jameslt1TA
I wouldnt bother with it . Too little of an increase for all the work and money involved.
i'd say 9ft-lbs to the ground is a significant increase, esp on a V6 car
blue98SS
Jul 3, 2002 04:18 PM
