No upshift
Old Oct 17, 2005 | 12:17 AM
whiterocket28's Avatar
No upshift
Well i have been reading some posts that are similar to the problem that i have with my but they are not exactly the same. Anyway if you have it half or full throttle it does not shift to the next gear it just reves up. I have hear and seen some things to try but i want to make sure that they would be good ideas to tryout. Well first is the tps sensor if it is bad or adjust the shifter arm. If any one has any other ideas please help out.
Old Oct 11, 2006 | 05:13 PM
DelSoto's Avatar
Re: No upshift
I would like to know as well....just replaced motor...had A4 rebuilt last fall. The car used to shift very hard into second now it is mushy and at full throttle it hits the rev limiter before shifting. I have to let off the throttle....wait for shift....then go again. Thanks!!
Old Oct 12, 2006 | 12:37 AM
Performabuilt's Avatar
Supporting Vendor
Re: No upshift
well on the mushy shift and possibly on the no shift it may be a bad pcs (preasure control solinoid )If so if you havent done any damage yet you can just replace it
Dan K
42
Jul 20, 2012 03:14 PM
davepl
Jan 17, 2004 03:43 PM
bruecksteve
Oct 3, 2003 11:32 AM
