4L60 vs 4L60E
Old Sep 27, 2005 | 07:01 PM
viper03af's Avatar
4L60 vs 4L60E
i'm not sure if i want to get a 4L60 with vavle body i can shift at the track and let it shift on the street ( cheaper lol) or the 4l60E straight up
what the pros and cons of it?
also the 4L60 will be alot easier and cheap to install also ( converting from a T-5)
new to the auto world any good advice is welcome
Old Sep 27, 2005 | 09:59 PM
93LT1355's Avatar
Re: 4L60 vs 4L60E
I would go with the 4L60 for the simplicity. Also I'm not sure about this but would have you to change your computer to run the electronic tranny?
Old Sep 27, 2005 | 10:02 PM
viper03af's Avatar
Re: 4L60 vs 4L60E
no i have to buy a wriring harness wire it in and use hp tuners to flash it to a auto car and transfer my tune over
but the harness is 175 bucks plus the hassle
Old Sep 27, 2005 | 11:52 PM
93LT1355's Avatar
Re: 4L60 vs 4L60E
It wouldn't be worth the hassle to me and I like the fact that I have control over the transmission (for the most part) and not the computer
Old Sep 28, 2005 | 07:20 AM
viper03af's Avatar
Re: 4L60 vs 4L60E
yeah i'm thining the same thing...
anyone else ??
Old Sep 28, 2005 | 10:22 AM
rngilliland's Avatar
Re: 4L60 vs 4L60E
You will need a tv cable and throttle body that will let you use it for the 4l60.
If your car is a 97 3.8 I don't know if the throttle body is available. If its an LT1 you will need a 93 throttle body. I would go with the 4l60e.
Old Sep 28, 2005 | 04:41 PM
viper03af's Avatar
Re: 4L60 vs 4L60E
what kind of TB do it need? its a cable TB....... please more info
Old Sep 29, 2005 | 12:11 PM
Re: 4L60 vs 4L60E
I'm assuming you have a 97 v6. To use the 4L60 you will need to hook up the tv cable from the trans to the TB. I don't know if a v6 TB has a place to connect the cable but I doubt it. As far as I know you have to have the tv cable to use a 4L60.
Old Sep 29, 2005 | 01:05 PM
93LT1355's Avatar
Re: 4L60 vs 4L60E
the 4L60 will not work properly without the TV cable.
Old Sep 29, 2005 | 06:27 PM
viper03af's Avatar
Re: 4L60 vs 4L60E
err i'm new to auto but what does this do? what is the pupose of it ?
Old Sep 30, 2005 | 11:13 AM
Re: 4L60 vs 4L60E
The tv cable controls the shifting. It must be used and properly adjusted to use the 4l60.
Old Sep 30, 2005 | 04:21 PM
viper03af's Avatar
Re: 4L60 vs 4L60E
i see i thought they ran off vaccum lol i'm going wit hthe 4L60E wit ha trans brake
thanks for your inputs
Old Sep 30, 2005 | 05:03 PM
sseeya's Avatar
Re: 4L60 vs 4L60E
You don't need the whole throttle body. All you need is the throttle cable bracket from a 93. You can get one from any GM dealer.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
