question on 4L60E problems
Old Oct 21, 2005 | 06:13 AM
camaro81's Avatar
I got my 95 camaro tuned about a year ago when I had my 3.73's put in and the dude set the transmission up to shift harder through the computer. It's been hitting 2nd gear pretty hard for a while and I've got nearly 100 passes on the car since then.
A few months ago at the track, I put the car in reverse and it wouldnt go anywhere, it was like someone blocked my wheels or something. It went forward just fine. After I went from drive to reverse a few times, it finally moved. I didnt have this problem again until last saturday when I heard a loud BOOM on the 1st - 2nd shift. But ever since then I've had a mild vibration going up through the drive train.
Now the car wont budge in reverse unless I rev it up a few times, then it slams into motion and whines loud as hell. I have the same problem when I put the gear selecter in 1st gear, yet it drives fine if its in 2nd or 3rd. It will still pull in overdrive, but it makes a loud whining noise just like it does in first and reverse, but only at highway speeds.
Any idea what kind of failure caused this? I've blown a ****load of TH-350's in the past and thought I've experienced every type of transmission failure there was, but this one is new to me.
Old Oct 21, 2005 | 04:40 PM
12SCNDZ's Avatar
Re: question on 4L60E problems
...Sounds like your rear planetary has bit the dust
Frank
HectorM52
Jul 30, 2017 11:46 AM
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
