another underdrive pulley question
Old Jun 5, 2003 | 09:36 PM
slayer6x6's Avatar
would i need a different size belt with underdrive pulleys on the crank and alt.? if so, what size would i need?
Old Jun 5, 2003 | 11:17 PM
Nitromethane's Avatar
Yes you need a new belt, no I don't remember the belt length. We had to try 4 or 5 belts for mine since I also removed the air pump.
Old Jun 6, 2003 | 12:43 AM
IROC-T
Guest
Posts: n/a
Belt size
I'm running the March Power 'n' Amp pulleys and the belt number on mine is #5060945DR , that will get you close.
Good Luck T.
Old Jun 7, 2003 | 08:51 PM
slayer6x6's Avatar
i went with a belt that was 2cm smaller than the stock belt and worked perfect. i guess the guy before me peeled off the sticker that shows the belt routing so i had to play with it for a little bit to figure it out.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
94z28jbw
Sep 8, 2002 03:22 PM
