L98 idles at 1500 in park......
Old Jun 3, 2003 | 11:08 PM
stanghunter211's Avatar
Hey guys, well I have been battleing this problem for over a week now. The car fires up in the morning and once it smoothes out, climbs to 1500 and WILL NOT kick down...... I shut the car off after nearly 15 minutes, and then restarted it, it idled at around 1K....... Why is this? It reminds me of the choke on my 86, stuck, but I know this is not the case..... Anyone ever run into this before??? I am really starting to worry here. Could this all be that damn IAC sensor? Are they really that ****ing annoying??? Thanks guys.
Old Jun 3, 2003 | 11:23 PM
96LT14u2Nv's Avatar
possibly the MAF burn off sensor or relay. or mabey something to do with the IAC or TPS sensors
Old Jun 3, 2003 | 11:25 PM
MOTHER ****ING Pos, lol, I get no codes...... what gives
Will
Old Jun 4, 2003 | 07:54 AM
Nitromethane's Avatar
Mine idles high, then i tap the gas pedal for like 1/10th of a second n it falls back down to 600-700rpm. Make sure TPS is set correctly, remove the IAC and clean it thoroughly, clean out your throttle body, then try again. My moms 91 vette was having the same problem, i think the IAC lines were clogged up or something, I don't remember exactly, but it was a fun car to drive, u let go of the gas n the car would shoot forward lol.
Old Jun 4, 2003 | 11:18 AM
aklim's Avatar
Tried cleaning the TB and IAC and readjusting the TPS yet?
Old Jun 4, 2003 | 05:43 PM
Not yet, I cleaned it the TB, bt not the IAC or adjusted the TPS. I don't know how yet, and I will be doing it this weekend. ALl fingers point to this... THanks guys
Will
Old Jun 6, 2003 | 11:44 AM
ds5's Avatar
ds5
Smile
you might have to replace your cpu... exact same thing happen to me... changed all sensors with no luck... mechanic worked on it for 2 days... finally a ground wire was frying the cpu... just a hunch
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
Double aught
Oct 2, 2015 11:29 PM
Tarizza
Sep 20, 2015 03:26 PM
tdigger9899
Sep 7, 2015 10:56 AM
