Computer Chip key
Old Jun 2, 2003 | 03:45 PM
Camaro Genius's Avatar
Question Computer Chip key
I bought a 91 RS for $150 because of a bad Key, her son tried to change the ignition switch w/ a hammer and screw driver. Has anyone ever bypassed the VATS and just run a toggle swith? Thi car is eventually going to be my victim for the northstar, buut I'd like to drive it on the 3.1 for a while. I plan on grinding the column smooth, and bondo-ing ove the gaping hole where the key switch went.
Old Jun 2, 2003 | 07:35 PM
TheGreatJ's Avatar
You need the original key to bypass VATS. All you have to do is check the resistance across the contacts with a multimeter, then go to RadioShack and get a resistor of the same (or evry close) size. If you don't hame a multimeter, take the key to the store and try to talk them into checking it for you, or letting you "test drive" one of their multimeters.
When you get home, unhook the connector at the bottom of the column (2 tiny white wires in an orange sleeve) and splice the resistor into the OTHER side of the connector (not the tiny wires.) Tape it up and leave it be. That's it, you're done.
Old Jun 3, 2003 | 07:21 AM
That's the whole prob. the key is no good. It got magnetized or something.
Old Jun 3, 2003 | 09:33 AM
aklim's Avatar
It is a resistor chip not a magnetic chip. You might have to bring it to GM to get it scanned.
Old Jun 3, 2003 | 06:21 PM
TheGreatJ's Avatar
You don't have to take it to GM, and a magnet won't hurt it. Just take a multimeter (set to read resistance) and touch one lead to each side of the "chip." Whatever it reads, that's the size resistor you need. You can get a resistor at RadioShack for about $1.
Old Jun 3, 2003 | 07:39 PM
Aron213's Avatar
You can bypass the vats by just getting someone to burn you a chip with the VATS disabled. Then the computer doesnt even know its there!
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
4586
Dec 6, 2014 05:20 PM
Jul 4, 2005 05:00 PM
