tpi?????????/
Old May 15, 2003 | 08:53 PM
crazyk1le's Avatar
Unhappy tpi?????????/
i just saw a tpi motor go 9.98 and 135 mph in the 1/4 ???
what is the real storie on tpi can you make these things co for under a million dollars or what, i know i've been talkin your guys ear off about this but i keep gettinmixed things if i built a 355 using mostly gm parts fast burn heads zz4 and what not can i expect good things, also how did this guy go 9.98 with tpi i thought it couldn't get that kind of air through it
Old May 15, 2003 | 10:37 PM
doug791's Avatar
maybe he was running a powerful turbo? I dont know for a fact but id assume if you had enough power running through a turbo you could cram in enough air to get it that fast the engine would have to be made bullet proof though first
Old May 16, 2003 | 07:02 PM
dave89gta's Avatar
If that is true, he has a lot of work done to the engine. And there is no way in hell it is with the factory style TPI.
Old May 16, 2003 | 09:02 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
There are many TPI based systems he was probably using. The Super-ram, or SLP T-ram. All are technically TPI but not the factory system.
Old May 16, 2003 | 09:15 PM
crazyk1le's Avatar
Lightbulb reply
nope he had a beefed up stock system i'll look for it again and show you guys where to go see this monster he has to have nitrous i'll get back to you
Old May 16, 2003 | 09:46 PM
crazyk1le's Avatar
Unhappy found it
after further review of the video he has a supercharger on his camaro check it out on this site
www.sethirdgen.org
it's the maroon one down on the right in the video list check it out
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
dfarr67
Apr 10, 2015 07:44 PM
