trans cooler install
Old Jun 1, 2003 | 12:52 PM
ghostle's Avatar
I`m installing a cooler for my trans. The directions say to start the motor and put it in drive for 10 seconds. Then feel both lines going to the rad. The cooler is the return line. Mine felt the same temperature. Does anyone know if the return is the top or bottom line? This is on my `86 camero. Thanks!
Old Jun 1, 2003 | 02:31 PM
Nitromethane's Avatar
Usually the bottom one on the radiator is the return line. How about you take one off n see if it spits out or sucks in? With car running.
Old Jun 1, 2003 | 03:12 PM
ghostle's Avatar
I`ll take the bottom off and check it. Thanks for the quick help.
Old Jun 1, 2003 | 03:16 PM
TheGreatJ's Avatar
It's best to take it off with the car not running, then unhook your distributor wire (so she won't fire up) and just turn it over a few times. It'll spit enough to tell which way the fluid flows.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
thenewkid
Nov 27, 2014 09:41 AM
