TH350 install?
Old May 18, 2003 | 04:46 PM
gravity plus's Avatar
TH350 install?
Alright, my friends 700r4 has about had it. It's got about 125,000 miles on it now and its starting to show. He pretty much has his mind set on a new th350 w/ shift kit. My question is...If a shop installs it, will they run into any problems (ie. will the mounts need to be moved/ new mounts bought?) or anything that my friend needs to buy so the tranny will bolt right up?
Thanks guys/gals.
Old May 18, 2003 | 10:06 PM
slayer6x6's Avatar
i know my local speed shop sells a th350 swap kit for our cars. not exactly sure what it contains of, maybe it relocates the trans mount or cross member??
Old May 18, 2003 | 10:19 PM
TheGreatJ's Avatar
It requires a different crossmember and driveshaft, although I can't remember if the TH350 is shorter or longer than the700-R4.
Old May 18, 2003 | 11:05 PM
slayer6x6's Avatar
im pretty sure that the th350 is shorter than a 700r4
Old May 19, 2003 | 10:44 PM
mrr23's Avatar
b/m30299 is the 700r4 to th350 conversion kit.
http://store.summitracing.com/partde...rt=BMM%2D30299
you will need a th350 with the 9" tailshaft. of would need to get a driveshaft about 3" longer. or can get a driveshaft out of an 82 camaro with the th200 in it.
Old May 20, 2003 | 01:49 AM
stangkilla1's Avatar
I've gone through 2 700-R4's in my 86 Z-28. In both trans. 2nd and 4th gear were stripped so I bought a B&M 350 turbo with heavy duty gears and a stage 2 B&M shift kit from Summit ($950). I had to get the changeover kit (summit) and have my driveshaft extended 2 1/2 inches. It working great for me. The only things you have to deal with is:
1) rear end issues, I wind out at 110mph vs. 140+ with the 700-R4. I'm changing from 2:73 to 3:73
2) crossmember and bushings. My shift kit kicks so hard that it shakes all my crossmember bolts and bushings loose. Anything past 3000rpm in first will have me sideways when I hit second!!
You have to understand that with the stock rear your gonna have a quarter car ,but it's sooooo worth it until you get at least 3:73 or better.
Old May 20, 2003 | 08:17 PM
TheGreatJ's Avatar
Dude I hate to break it to ya but going from 2.73's to 3.73's is goint to take a substantial amount OFF your top speed, not add to it. If 2.73's makes it a quarter car, then 3.73's will turn it into an eighth-mile car. You're gonna top out at like 90.
Old May 20, 2003 | 08:45 PM
STANGeatinZ's Avatar
why did changing transmissions drop your top speed so much? I know it doesn't have overdrive, but my overdrive doesn't pull much anyway. And 3.37's are going to kill top speed even worse.
Nov 18, 2023 07:21 PM
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
