tpi
Old May 31, 2003 | 10:42 PM
crazyk1le's Avatar
Question tpi
i want to run a 327 or zz4 with slp or accel runers , accel intake ported plenum, 52mm throttle body, 22lb. inj. my real question is what can the stock ecm do, can i do these changes without getting a cust programmable one(like calmap), will i be able to just get a custom chip, also in the future i was thining of supercharging willi have to change the computer then for sure or can i still just use a chip
Old Jun 1, 2003 | 12:51 AM
IROC350's Avatar
yes, you will need a custom chip for the car...go ahead and do it now. i think you might have to anyway
Old Jun 1, 2003 | 10:23 PM
crazyk1le's Avatar
Question tpi
you think all i'll need is a chip also, i want to change to speed density do i need to change my comp.
Old Jun 1, 2003 | 10:57 PM
Aron213's Avatar
You will need a 730 ecm and the correct wire harness and sensors to swap to S/D
Old Jun 3, 2003 | 09:52 PM
crazyk1le's Avatar
Talking s/d
thanx for the info i heard the later yrs were the best ecm is that true, also i heard if i go n/a i should use maf is that true
Old Jun 3, 2003 | 11:07 PM
Aron213's Avatar
A 730 ecm is a 730 ecm that is your choice for SD...if your going to be tuning and making it exact then SD is the way to go, if your not tuning than MAF will be the way to go because its a little more forgiving.
Old Jun 5, 2003 | 12:20 AM
crazyk1le's Avatar
Unhappy ecm
excuse me on the ecm ignorance, but this end is new for me anyways the 730 i'm guesing is a gm com. and if so when i tune it is it comp. reprogramable or is it like burning a chip or is that the same thing?
Old Jun 5, 2003 | 06:13 PM
Aron213's Avatar
the ecm is the silver "brain" under your dash..the Prom goes into the ecm....you program the prom, the ECM holds the hard data.
Old Jun 8, 2003 | 01:26 PM
aklim's Avatar
You could keep your setup and have someone custom a prom for your Mass Air unit with less problems. I know that www.fasterproms.com does do it truely custom to your car and they reburn it twice after taking readings to make sure it is on the money.
Old Jun 8, 2003 | 03:24 PM
Glimmer's Avatar
If SD is so great, why did they go back to MAF on the LT1 and forth?
Old Jun 9, 2003 | 09:54 PM
aklim's Avatar
AFAIK, Mass Air gives you the true volume of air and SD estimates it. You could stick intakes on a MA system and not have to reporgram the EPROM whereas, to get the max out of an agressive intake on SD, you will have to reprogram. At least that was my experience. SD has less obstructions but is harder to work with in that the window of adjustment is smaller and therefore less adaptable.
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
dfarr67
Apr 10, 2015 07:44 PM
