90 Iroc Mis At Idile
Old Jun 3, 2003 | 11:36 AM
RONALD SHAPIRO's Avatar
HI I HAVE A 90 IROC5.7 16,000 MILES .IT HAS A MIS AT IDLE .I CHANGE THE FUEL FILTER WHICH WAS CLOGED .CAP ROTOR WIRE PLUS.CLEANED INJECTORS.DID NOT CHACK FUEL PRESSURE YET .NO CHECK ENGINE CODES.PASS EMISSION TEST .TACK DOES NOT MOVE.EGR LOOKS OK.COULD IT BE A BAD INJECTOR.LISTENED TO THE INJECTOR SOUND THE SAME. THANKS RON.
Old Jun 3, 2003 | 05:46 PM
stanghunter211's Avatar
When you replaced the cap and rotor, did you plug all the wires back in??? My old HEI setup got the tach signal from the dist. I am new with this TPI game
Will
Old Jun 3, 2003 | 08:00 PM
aklim's Avatar
Better yet, did you get the wires plugged in correctly? How are your injectors? You might have to go to a tech college with them and have them flow checked.
Nayr
Mar 3, 2023 08:34 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
