Need a trouble code decoded.....
Old May 13, 2003 | 05:01 PM
Smooothie119's Avatar
Question Need a trouble code decoded.....
I was hoping that maybe some of the experts here could tell me the meaning of the code that my computer has stored. I used the paperclip method and after displaying the usual code 12 3 times, it flashed another sequence: flash, flash, flash, pause, flash, flash, flash, flash. It also displayed this one 3 times as well. Please help.....
Old May 13, 2003 | 05:03 PM
amc91z's Avatar
code 34 is for the Vacuum sensor circuit....
Old May 13, 2003 | 05:15 PM
Unhappy
ok, I know where the MAF sensor is, but where is the MAP sensor? How many vacuum lines are on these TPI engines? And if I did a thorough search of the engine bay, would the faulty line be obvious? Sure wish I had one of those repair manuals, but I'm seriously strapped for cash...
Old May 13, 2003 | 05:39 PM
I swear this car is playing games with me.....I just went outside and checked all the wiring harnesses under the hood and made sure they were all fastened. I checked all the vacuum lines I could see and everything seemed ok. I tried starting the car and she started right up like nothing was wrong.
This all started with the car refusing to stay started as soon as it cranked over. It would taked bewteen 3-10 times until it would finally turn over and stay running. And once it was running, the car would be fine. When I first posted this prob, many said it may be an old fuel filter. At the time I did'nt know how to check the SES codes so I don't know whether or not another code was tripped at some point. I guess I should of seen this coming. About a month or so ago the car was acting funny upon first starting it up. It would idle really low for a sec as if it was gonna die, and then idle up near 1200 or so rpms until it warmed up. Now this.......
It seems as though it runs the worst when I need it the most.
Any ideas???
Old May 14, 2003 | 08:36 PM
Question
anyone??
Old May 14, 2003 | 09:11 PM
88Birdowner's Avatar
I have a MOTOR company book that goes up to '88 for F bodies, what is it you need? Go ahead and e-mail me...
Old May 15, 2003 | 11:06 AM
what is the MAP sensor & where is it located?
Old May 15, 2003 | 12:39 PM
aklim's Avatar
It should be hooked onto the intake plenum. It is a black box with a plug with 3 wires hooked into it. It also has a short hose going to the manifold.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
