91' and 70' model blocks the same??
Old May 28, 2003 | 11:01 PM
stockLT1's Avatar
I have a 70' model sbc block.....will my accessory brackets off of the 91' fit on the older one (without drilling and tapping new bolt holes)?
Old May 28, 2003 | 11:15 PM
Aron213's Avatar
yes, but your oil dipstick will be on the other side of the block...and your acc. bolt mainly into the heads not the block.
You will have to use a 2 piece rear seal flexplate/flywheel.
Old May 28, 2003 | 11:23 PM
stockLT1's Avatar
So I will have to drill and tap the head then?
how many accessory bracket bolts are there?
Will the 91' H2O pump work?
Old May 29, 2003 | 07:59 AM
Greed4Speed's Avatar
Only differences I know of are the rear seal design and the 91' would be a roller cam block.
Old May 29, 2003 | 12:55 PM
Jim85IROC's Avatar
if the heads don't have the accessory holes, you need new heads. I don't think most of those heads had enough material to safely drill the accessory holes.
As long as you're taking head differences into account, remember that the 87+ heads had the different bolt angle on the center 4 manifold bolts. The 87+ blocks also used roller cams, except in the trucks, but I think those blocks were still cast the same as the roller motors.
Old May 29, 2003 | 05:05 PM
Aron213's Avatar
can you just use your heads from your 91, they will match your intake and everything else....also from mid 68 to current gen1 sbc the heads are machined with the correct bolt holes, but the exhaust manifolds from newer heads will not fit older heads I think they moved the first bolt hole out a little on the exhaust manifold. Headers are different story.
And the answer to your question...three bolt holes on the front of the heads
Old May 29, 2003 | 10:55 PM
stockLT1's Avatar
Cool, thanks for the info. I think I am going to use some double humps, but I'm not sure yet.
I have access to a milling machine, so the headers won't be a problem. I have a set of ceramic coated hooker shorty's for it.
Old May 30, 2003 | 09:21 AM
Don't waste your time on double humps. Grab a set of new Votec heads. They cost a little over $400 and flow way better than double humps ever did.
Old May 30, 2003 | 10:01 AM
Jim85IROC's Avatar
Too bad that you also need to cough up another $400 for a new intake manifold.
Old May 31, 2003 | 02:36 AM
stockLT1's Avatar
New intake manifold?? for what?
I have a Weiand accelerator...I am going to run a set of 885 heads on it.
Old Jun 1, 2003 | 02:10 PM
Nitromethane's Avatar
Accessories will fit, heads should have bolt holes or you have a weird stupid set of heads you shouldnt be using anyway, everything is interchangable except the lifters, crank and flex plate, if you use the 91 heads you need to use the 87&up intake, or modify the holes on the 86&down intake.
Old Jun 2, 2003 | 11:29 PM
stockLT1's Avatar
Cool....I have a set of 885 400 sbc heads for it.
Old Jun 3, 2003 | 08:33 AM
BLOWN25TH's Avatar
I dont know if all the issues have been adressed here. First of all you are going from a roller block to a non roller block. With this exchange you will need to either purchase retro fit roller lifters for your roller cam or go solid,hydraulic flat tappet along with a new cam. If you go solid,hydraulic flat tappet you wil need to purchase new pushrods. Because the roller pushrods are shorter than non-roller. Also if you heads contain guide plates you will need chrome molly push rods. I wouldnt really worry about the manifold bolts as stated earlier because you can modify those middle bolts to fit the diffeerent angled head screws. Just drill them out and they wiil fit. I just went through this exchange with my camaro. And it can get costly but i think going from a two bolt main to a four bolt main is woth it. I dont really see alot of power loss from going roller to non roller as long as you have roller rockers. Good luck with the exchange.
Old Jun 3, 2003 | 11:37 PM
stockLT1's Avatar
Yeah, I knew that. Thanks for the input......I am going to run the flat tappet lifters and cam on it, I will also run 70' model heads and intake etc. Motor combo won't be an issue, only the accessory brackets.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
