tpi
Old May 31, 2003 | 10:34 PM
crazyk1le's Avatar
Talking tpi
what do you guys think of a 327 under a tpi unit
Old May 31, 2003 | 11:46 PM
AlabamaOutlaw's Avatar
I think not.
Old Jun 1, 2003 | 12:49 AM
IROC350's Avatar
Old Jun 1, 2003 | 01:42 AM
stevem's Avatar
327's can rev nicely
Old Jun 1, 2003 | 02:08 AM
Dirt Reynolds's Avatar
Precisely the reason it's not the best choice for the TPI induction.
Old Jun 1, 2003 | 10:27 PM
crazyk1le's Avatar
Unhappy 327
so you don't think it will work has anyone tried it, would a diff. type of injection work on it like a lt1 type intake
also i want to run a hyd. roller cam what does it take to convert a old block to run one
Old Jun 1, 2003 | 11:01 PM
Aron213's Avatar
a couple of people have tried it, but TPI's dont like to breath over 4500 stock, about 5200 modified so it doesnt match up to the powerband of a 327 to well. A HSR, lt1 intake or a miniram would be a better choice...if your stuck on wanting to use a 327.
You will need retrofit roller lifters
Old Jun 2, 2003 | 07:40 PM
Nitromethane's Avatar
You'll need retro-fit hyd. roller lifters (the type that connect 2 lifters with a crossbar to keep them from rotating), and a roller cam button to keep the cam from "walking" in the block, and a cam bolt locking plate to retain the cam button and keep the bolts from loosening up, other than that, just the usual stuff, valve springs, locks, retainers etc.
Old Jun 2, 2003 | 08:41 PM
TheGreatJ's Avatar
Those retro-fit roller lifters are pricey too. It'd be much cheaper and easier to just use a roller block.
Old Jun 3, 2003 | 09:50 PM
crazyk1le's Avatar
Talking 327
thanx guys that was good advice also looking for advice or should say some info,
1) what does the smog pump do (i know it was supposed to make cleaner air) but i maen what does it really do or should i say how does it do it?
2)durring the visual test what will they look?
3) will a tpi car pass without out it really working?
what i'm trying to do is decide carb or tpi if i go carb i'm gonna throw a roots blower on top and try to make it pass emissions the real questions in the cars that were carb'd did they have a smog pump ( were they using one in the 82' model year)
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
dfarr67
Apr 10, 2015 07:44 PM
