driveshaft question
Old May 19, 2003 | 09:28 PM
slayer6x6's Avatar
driveshaft question
will an aluminum driveshaft from an 4th gen fit in a 3rd gen. a guy is selling one on ebay for pretty cheap.
Old May 19, 2003 | 09:41 PM
Dave89IROC's Avatar
yes, driveshafts from 85-02 are interchangable, 82-84 also if it has a 700r4 or t-5
Old May 20, 2003 | 07:57 PM
TheGreatJ's Avatar
What he said.
Old May 20, 2003 | 08:03 PM
doug791's Avatar
is the aluminum drive shaft a stock option? or are they aftermarket add ons?
Old May 20, 2003 | 08:38 PM
slayer6x6's Avatar
its aftermarket
Old May 20, 2003 | 08:39 PM
TheGreatJ's Avatar
In the 3rd gens you could only get an aluminum driveshaft stock if you ordered the 1LE option. They're stock in all LS1 and many LT1 4th gens though, and they are a direct bolt in. You can also get them aftermarket from Lingenfelter...but they're pricey.
Old May 20, 2003 | 09:14 PM
CODY BEHNKE's Avatar
I know of 3 all stock 3rd gens with aluminum shafts and not one is 1LE.
Old May 22, 2003 | 06:55 PM
91ReDZ's Avatar
The aluminum driveshaft was rpo JG1 and was put on many G92 third gens
Old May 22, 2003 | 08:12 PM
TheGreatJ's Avatar
OK so it was G92 not 1LE.....sorry I'm not as current on RPO's as I am on general mechanical knowledge.
Old Feb 2, 2004 | 01:24 PM
841LE's Avatar
Both G92 & 1LE f-bodys had aluminium dr.shafts.I believe it was standard on 1LEs only,optional for all others though.My 84z has one from a 88 T/A.Works w/both 9/10 bolt rearends.Even 700r/T5.
Old Feb 2, 2004 | 01:27 PM
RobsWS6's Avatar
The TSB that allowed replacement of the stock steel shaft in LT1 F-Bodies was the 1LE aluminum from a 3rd gen.
LS1 cars got aluminum standard.
Old Feb 2, 2004 | 02:01 PM
Blown350ZZ4's Avatar
I just put an aluminum driveshaft in my third gen and it was real easy. I put up a post in drivetrain and someone recomended that i just take it to the local machine shop and have them press in new heavy-duty u joints. That was the best way to go.
let me know if you have any questions on instillation.
Nick
Old Feb 3, 2004 | 12:29 PM
RobsWS6's Avatar
Originally posted by robvas
Except for the 2.73 LS1's. They got the steel shaft. Otherwise I'd pull my LS1 shaft and switch it with my IROC.
Whoops, should have said all 6spd LS1's got aluminum.
Old Feb 3, 2004 | 02:25 PM
Marc 85Z28's Avatar
3.23 auto cars got them too
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
