wierd accleration at highspeeds
Old May 31, 2003 | 09:12 PM
lordmetalz28's Avatar
Unhappy wierd accleration at highspeeds
hey when im doing at about 65 on the freeway i hit my gas my car takes off then feels like it goes nuetral and then i push down on the accelarator more it finnally takes off is this normal. or does this sound like a tps problem
Old Jun 1, 2003 | 11:37 AM
Camaro Genius's Avatar
Sound like tranny trouble to me. one of my RS's is doing the same.Can you find one speed while cruising where the tranny goes hunting? like constantly shifting up and down?
Old Jun 1, 2003 | 02:40 PM
no it dosent hunt it just does that crazy thing i hop its not tranny ill try the tps friday
Old Jun 1, 2003 | 02:59 PM
Nitromethane's Avatar
Are you in overdrive when it does this? Do you have a high stall converter? If you do, it may just be your converter slipping below your stall speed - mine doesnt accellarate too well in overdrive with part throttle, n downshifts into 3rd with wide open throttle - but if its definately going into neutral, u have tranny troubles, may be time for a rebuild.
Old Jun 1, 2003 | 04:16 PM
well yes i am in overdrive when this does happen i dont know about the stall coverter i dont think theres one i bought pretty muuch stock but i do know my tranny is cleaner then the rest of the undercarraige sorta like it has already been rebuilt now it only goes neutral for a second until i hit the gas harder then it takes off
Old Jun 2, 2003 | 12:06 AM
Exclamation
If your tranny is broke, don't rebuild it, 700r4's are mediocre at best, find a 200, and build it. much better tranny!
Old Jun 2, 2003 | 07:46 PM
Nothing wrong with 700R4's, 518 ft lbs of torque goin through mine (392 ft lbs on motor) every single day n it holds up fine, friend of mine has beat the crap outta his 700R4 for a year now, nitrous n everything, he screwed up the converter and broke the governor gear so tore the tranny down, everything looks like new.
Old Jun 2, 2003 | 09:58 PM
i def dont think its my trans shes pulling fast and not slipping well find out soon
ChickenScreamer94
Jun 2, 2003 09:11 PM
OffspringZ28
May 8, 2003 10:44 AM
Dragons91RS
Mar 4, 2003 06:06 PM
eddiezlt1
Feb 14, 2003 05:36 PM
Ninety3Z
Jan 31, 2003 06:10 PM
