K and N drop in,s
Old May 24, 2003 | 10:57 AM
lordmetalz28's Avatar
Smile K and N drop in,s
hey does anybody know how much exact horsepower and torque i should get from those k n drop in filters for my tpi
Old May 24, 2003 | 11:10 AM
1fastformula's Avatar
Thumbs up
You will probably gain 2-3 hp (and thats being nice) and the same on torque. You gotta remember that all the little mods add up so do not let the above numbers change your mind. Check out www.thirdgen.org for a WHOL LOT OF FREE MODS to give you a little extra ponies.
Later
Old May 24, 2003 | 12:45 PM
87DJP2001's Avatar
Not to much HP/TQ gains,but at least you will not have to buy new filters in the future. This is the big plus with K&N and increased air flow.
Old May 24, 2003 | 08:30 PM
doug791's Avatar
the other idea is that if you want to do massive mods to do up the rest of the engine dropping on new intakes and heads and headers etc will do absolutly squat if the engine cant get enough air to run and even if youre not going to do all of that (which you should *waves fist angrily*) you also dont have to replace them so either way its win win
Old May 25, 2003 | 01:10 AM
AlabamaOutlaw's Avatar
I dropped them into my TPI Iroc. And im more than happy with them. First thing I bought for it. And all of my cars have them..And it aint just horse and tq u get. and not having to buy another EVER. its the fact that they will save you so much at the gas station it aint even funny.
If you dont buy them, your crazy.
Old May 25, 2003 | 07:19 AM
87DJP2001's Avatar
Just remenber the K&N filters require cleaning and LIGHT re-oiling as conditions require,
Old May 26, 2003 | 11:22 PM
Smile check this out
ok im defiantley going to pick thos up but i ws reading and wondering if buy those filters, remove the screens from around my mas air flow sensor , take the baffles out of my boxes , by pass my tb coolant and eventually get a air foil how much hp/tq will i gain ???? and before im done i plan on going with the edelbrock 52mm t body and grinding down that little wall in my manifold for more air then eventaull longer runners but for now. id like to know about the removing of baffles, tb coolant bypass k n drop ins , removing screens from mass , and air foil how much it would do for me.
Old May 27, 2003 | 06:50 AM
87DJP2001's Avatar
Well two things I would forget about to start are:
1) 52mm TB- reason to big for your engine.
2) descreening the Maf=more problems then its worth.
The other Items are ok and they will give you some small gains,
again they will not turn a stock engine into a performance king.
Old May 28, 2003 | 07:35 PM
ICEmanZ's Avatar
K&N Air Filters are worth the money... they add a few extra ponies, add some torque, and i have even noticed a slight increase in fuel economy!
it's a great buy, you can't go wrong... don't be afraid!
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
