what flywheel does it have?
Old Jun 3, 2003 | 09:17 AM
john-e-boy's Avatar
I am not at home so I can't look, I need a flywheel and don't know which one to get.
I have a 1992 camaro RS with a 350 TPI L98 in it from a 1990 GTA. Which flywheel is it:
14 1/8 inch diameter, 168 tooth dual bolt pattern and no weight
14 1/8 inch diameter, 168 tooth dual bolt with weight
12 7/8 inch diameter, 153 tooth and no weight
12 7/8 inch diameter, 153 tooth with weight
these are my options, if you can help I would appreciate it
John
Old Jun 3, 2003 | 10:20 AM
IROC350's Avatar
just to clear something up...didn't the AT cars come with flexplates?? is there any major differences between flywheels and flexplates???
Old Jun 3, 2003 | 06:26 PM
TheGreatJ's Avatar
There's a BIG difference between flywheels and flexplates, but most people just call them all flywheels because they mount in the same place and look somewhat similar.
I don't remember whether your engine uses the 153- or the 168-tooth, but you definitely need a flywheel with NO weight. The L98 is an internally balanced engine.
Old Jun 3, 2003 | 07:19 PM
john-e-boy's Avatar
OK sorry I forgot to mention that it for a 700R4 so yes I need a flexplate.
I talked to a tranny shop and he said the one with weight?? If I got the one with no weight wouldn't that through off the balance of the engine internally?? I thought the purpose of the weights was to balance the flexplate with the internals of the engine??
Can someone clear up the confusion I am having and also if its 153 tooth or 168 tooth??
How about a good place to get a performance flexplate??
John
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
