Turn signal question...
Old May 23, 2003 | 08:25 PM
thezisking's Avatar
I have an 86 z-28...The turn signals blink very rapidly and I want it to stop. Anyone have a clue how to fix this? It's annoying as hell! Both sides do it and it also does it with my hazzards. Thanks for any help!
Old May 23, 2003 | 08:29 PM
thezisking's Avatar
One more thing... It's done this since I've got it. I haven't tried anything yet. Don't know where to start. Thanks Again!
Old May 24, 2003 | 09:20 PM
pigsticker's Avatar
sounds like you need to replace the flasher relay. they're usually located in the fuse box.
Old May 25, 2003 | 01:13 AM
rdetke's Avatar
yes i think you need to replace the flasher relay i do belive
Old May 25, 2003 | 12:09 PM
87DJP2001's Avatar
The Flasher relay is located under the right side of the dash. I hope you have small hands because its a tight fit. Turn your flashers on so you can feel its vibration.
Old May 25, 2003 | 06:05 PM
dave89gta's Avatar
Ummm, I would make sure you have the correct bulbs in first. That could be your problem.
Old May 26, 2003 | 02:28 AM
thezisking's Avatar
Thanks guys! Will check that tomorrow!
Old May 27, 2003 | 03:16 PM
thezisking's Avatar
I changed the flasher on the turn signals and it DID worked... I unpluged it and pluged it into the hazzards and it fized that problem too...Going to get another flasher right now...Thanks Guys! Can't beat $2.00 a piece for something not to be annoying.
Old May 28, 2003 | 10:10 AM
IROCBeerBeer's Avatar
thats funny cause mine do the exact opposite, kind of. during the day they work fine, but as soon as i flip on the headlights the turn signals go slow as ***** hehehhe
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
