Tell me if this TV Cable is broken or if it sounds like Im doing something wrong?
Old May 23, 2003 | 08:20 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Im so sick of that stupid *** cable. I think Im just gonna put a TH-400 in so I odnt have to deal with it.
I push down the little tab and slide the black peice all the way back. Then I release the tab get into the Z and push the pedal all the way to the floor with the mats taken out. I heard its supposed to click a few times and the black peice will come back out to the proper length for the set up.
Well the clicks dont occur and the black thing just stays all the way in. Does that sound like its broken?
I thought maybe I could just adjust it manually for the time being. When I hit the gas where its at right now it feels like a have a high stall convertor. Does that sound like its too far away from the throttle or too close? If I knew which direction it needed to go I could just adjust it by hand trial and error style.
Old May 23, 2003 | 10:42 PM
AutoRoc's Avatar
erger
I definately don't like the TV cable either man. I have the Lokar TV and throttle cables and I THINK I have the TV cable as good as I can get it. I manually shift the car 100% now however since OD and D shift WAAAAY to early and slow. Manually it's fine though but I'm sure it's not the best thing to do with a stock trans. I actually slipped the trans when I first tried it on the street with the carb/new tv cable setup but now it's holding the 150 shot perfectly.... Goodluck!
Old May 24, 2003 | 10:52 AM
AndrewC's Avatar
TV Cable
Mine did the same thing when i went to adjust it. The tranny slipped or didnt move at all. I couldn't get it right, then the tranny packed it in. I was quite tired of this too and put in a turbo 350 instead. No more TV cable. Yeah.
Buy a B&M adapter or a Spohn torque arm and install a better tranny and you'll get better results out of your car anyway.
Old May 24, 2003 | 01:05 PM
DarthIROC's Avatar
Re: TV Cable
I thought that the TH-350s had a tv cable too. I thik I read that 73 and later ones did while the earlier ones didnt. I was going to go with a TH-400 because none of them have cables to my knowledge
Old May 24, 2003 | 03:19 PM
AndrewC's Avatar
tranny
nope they use a downshift cable on the throttle, much easier. Really easy to setup, and a much stronger tranny. Its also cheaper to get stall converters and parts for.
Old May 24, 2003 | 03:45 PM
Tobe2wild's Avatar
The pedal is supposed to be floored when you adjust it. So have someone floor it and then yank the cable back.
Old May 24, 2003 | 08:31 PM
DarthIROC's Avatar
That just might e crazy enough to work You mean have someone hold the pedal on the floor then I take the cable and slide it back as far as I can?
Old May 24, 2003 | 08:34 PM
slayer6x6's Avatar
you can just pull the throttle back at the throttle body, in my old z28 the cable was stretched so i had to make it a little tighter when i set it. that cable is a PITA!
Old May 25, 2003 | 07:10 PM
DarthIROC's Avatar
It would seem I have discovered the long plagueing problem. The Braket that I have the T.V. cable is in is held up by the carb stud. Well today I noticed that that carb stud moved . SO even when I had the braket adjusted corretly the braket would move and it would again not move. It turns out that the hole for the carb stud in the intake is stripped . I dont know what the hell Im gonna do know I really dont have the cash for a new intake.
Old May 25, 2003 | 10:16 PM
Tbird232ci's Avatar
check the cable where it attaches in the tranny, from what i remember its almost just a slip fit over a linkage in there, its possible it just came off
DSMKilla
May 26, 2015 10:10 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
vb95z28conv
Jan 27, 2015 08:32 AM
ModdedNerd
Dec 18, 2014 10:52 PM
Achilles97
Sep 12, 2002 11:57 AM
