starter or solenoid?
Old Jun 2, 2003 | 12:51 AM
Dragons91RS's Avatar
Question starter or solenoid?
Ive been having a problem off and on for the past month where my car wont start,and in the last week it has gotten to be more frequent . it wont crank or any thing, I turn the key and get nothing. the first time it happened I wiggled the thick uninsulated wire that goes between the starter and the solenoid and got it to start.
the next time it happened that didnt work, but I have found some thing that does. if I connect a wire to the big uninsulated wire and connect the other end to the battery for a few seconds I can hear what sounds like a small electric motor, then when I turn the key the car will start right up.
Im guessing its the solenoid going bad, but am not sure. what do you all think?
Old Jun 2, 2003 | 07:48 AM
FishPig's Avatar
My guess is you either are losing your solenoid or you have some loose wires that is causing a drain. Make sure all your wires are getting a good connection...You might try taking a few apart and cleaning the connectors. Otherwise I would say go ahead and invest in another starter. That way your not out on a date or late for work when yours decides to give up the ghost.....
Old Jun 2, 2003 | 07:16 PM
TheGreatJ's Avatar
On the occassions when it doesn't start....do you hear a "click" when you turn the key? If not, your solenoid is sticking and you just need to replace it. If it clicks and doesn't turn (which I doubt since it turns fine when you put power to the uninsulated jumper) then you need to replace the whole starter.
Chevy starters usually last a lot longer than the solenoids...but it may be hard to find somewhere that will sell the solenoid seperately. Generally they make you buy a whole starter and turn in yours as a core, then the reman company just replaces the solenoid coil, cleans it up, and sends it right back out.
Old Jun 3, 2003 | 09:11 AM
I cant remember hearing a click the other day when my wife tryed to start it wile I was under the hood, so it sounds like it may jusy be the solenoid.
Sadly it Looks like Im better off just getting a remaned starter w/solenoid. I can get one from O'reilly with life time warranty for $49.99
a solenoid alone is over $50
Old Jun 3, 2003 | 10:33 PM
Nitromethane's Avatar
AutoZone can test your starter. If it fails, u can buy a new one, they dont cost that much.
Formula Steve
Sep 19, 2023 08:31 AM
marlar98
Sep 19, 2015 07:53 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
