Air Pump question
Old Jun 6, 2003 | 09:08 PM
Patriot's Avatar
Air Pump question
Can I remove the air pump & crap that goes with it and not mess with the computer ? Any HP gains ?
Old Jun 6, 2003 | 09:37 PM
Nitromethane's Avatar
Dont know about hp gains but I think it helped my car, yes you can remove it, thirdgen.org has a tech article about belt routing on a serpentine.
Old Jun 6, 2003 | 09:40 PM
crazyk1le's Avatar
Unhappy air pump
doesn't that f$#k with the emmisions though
Old Jun 8, 2003 | 01:32 PM
aklim's Avatar
Only if you test it. It is supposed to pump air into the exhaust before the cat gets up to temp so that it has exhaust warming the air when it hits the cat. After it warms up, it sprays the air into the cat directly. It will not trip a sensor code. Remove it and reinstall before you go for testing.
Old Jun 8, 2003 | 01:36 PM
My county doesnt test emissions so I dont need to worry about that... I don't even have a cat.
Old Jun 8, 2003 | 01:46 PM
aklim's Avatar
Someday they might which is why I keep the air pump
Old Jun 8, 2003 | 01:57 PM
Well when that day comes I'll need to sell both my cars then No way in hell my Z will ever pass emissions.
Old Jun 8, 2003 | 09:41 PM
doug791's Avatar
i would love nothing more then to tear mine out but i get tested every two years
Old Jun 9, 2003 | 09:51 PM
aklim's Avatar
Wink
Remove it today and reinstall it when you are going to be tested and remove it when you pass the test. Repeat.
Old Jun 9, 2003 | 11:08 PM
doug791's Avatar
how intensive do you think it would be for someone who has basic mechanical skills but doesnt know a ton about cars to remove/reinstall.
Old Jun 10, 2003 | 12:33 AM
aklim's Avatar
Take the AIR diverter valve off and cap it where the intake manifold meets the one way valve. Remove all the tubing. Remove the AIR diverter. Take the serpentine belt off. Take 3 bolts off and the air pump comes off. Get a few belts from the store that are shorter than stock and try them on. Keep parts and old belt so you can reinstall if need be.
HectorM52
Jul 30, 2017 11:46 AM
linz
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
