zr1 wheels?
Old May 20, 2003 | 02:48 PM
stevem's Avatar
zr1 wheels?
has anyone put 17x11 zr1 wheels on their third gen.
how wold you do it.
i know you need the spacer?
pics?
Old May 20, 2003 | 04:36 PM
CRZYTRN-92Z28's Avatar
I haven't done it but have heard its not hard at all. Go here to find spacing and adapters. You'll need these adapters to make them fit. www.skulte.com . They have pics on their TT thirdgen.
Gl
Old May 20, 2003 | 04:42 PM
LT1Powered85Z's Avatar
Yes.
2" spacers or a 4th Gen rear. I have the latter of the two.
I don't have any pictures...yet.
Eric
Old May 20, 2003 | 07:33 PM
stevem's Avatar
will the 11 inch wheels work
Old May 21, 2003 | 10:40 AM
87GTA my 1st car's Avatar
I'm not sure, but you do need to know there are two ZR-1 style 11" rims...
You will need the GrandSport offset 11" ZR-1 style rims and NOT the ZR-1 offset 11" rims.
A ZR-1 has a wider rear than other C4s (look for the black spacers on each side of the rear license plate between the backup lights to verify you're following a real ZR-1).
The GrandSports also got 11" wheels but instead of making the doors flare and rear fenders and a$$ wider, they added the wheel well flares to keep the tires under the fenders. All C4s can accommodate the GrandSport offset ZR-1 wheels and have less than 1/4" sticking out on each side.
Old May 21, 2003 | 10:55 AM
11" is how wide ZR1s are. But yes, you need the Grandsport offset.
Eric
Old May 21, 2003 | 10:46 PM
kandied91z's Avatar
that's pretty wide..........10.5 is huge!
Old May 22, 2003 | 06:08 PM
Zepher's Avatar
Even with a 4th gen rear, you still need to do some modding.
Bumpstop has to be relocated and some minor inner fenderwell banging to allow clearance.
http://www.transamws6.com/pics/transam/gs02.jpg
The tire on that wheel is 335/35/17, not sure how much larger it is than the standard 315/35/17 tire.
Old May 22, 2003 | 11:09 PM
Modding and fenderwell banging isn't always necessary.
You're running a tire that's almost an inch wider than 315s. That's part of your problem.
Eric
Old May 22, 2003 | 11:45 PM
Zepher's Avatar
Eric
Is it that much wider!! I didn't realize it was almost an 1".
I do know that these dwarfed my 275/40/17's.
Old May 23, 2003 | 09:07 AM
Well 24mm is 1 inch, if I'm not mistaken. 335s are 20mm wider than a 315, so that's basically an inch more.
I personally wouldn't run 335s on an 11" wide wheel. Those are usually on wider wheels, which is what Vipers have. I've never seen a 335 on an 11" wide wheel, like a ZR1, etc.
Eric
Old May 23, 2003 | 10:12 AM
Zepher's Avatar
The 335 doesn't look all that big on the 11" rim. Here are some more pics of it,
http://www.transamws6.com/pics/transam/gs01.jpg
http://www.transamws6.com/pics/transam/gs03.jpg
http://www.transamws6.com/pics/transam/gs04.jpg
http://www.transamws6.com/pics/transam/gs05.jpg
Oh, the reason the wheel is sticking out is that I have a 2.25" spacer on my 4th gen rear just to see how the wheel looked with the car sitting on the ground since I didn't have time to take off the bump stop.
Old May 23, 2003 | 07:08 PM
stevem's Avatar
how much wider is the 4th gen rear
compared to the 3rd gen rear
Old May 23, 2003 | 08:14 PM
Approximately 2" on each side, so 4" wider total.
If you run a 3rd Gen rear with 4th Gen wheels, you need 2" spacers on each side (and up front too).
Eric
Old May 23, 2003 | 08:17 PM
stubbs's Avatar
I personally know 2 friends that are running 335/35/17's on their ZR1's, they have replaced the tires several times and have never seen the center wear pattern indictive of a tire too wide for a rim.
