TH400 Transmission
Old May 15, 2003 | 11:36 PM
99huggerorangeZ's Avatar
Question TH400 Transmission
i am thinking of replacing my TH700R4 with a TH400 but i am wondering how hard it is to switch crossmembers??
Old May 15, 2003 | 11:48 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I was thinking about doing this as well because I have a grudge with my TV cable and I heard TH350s have them too. What all has to be done? Doesnt it require a different drive shaft because of the larger yoke. And I read that you cant use log tube headers with them either because of a big casing.
Old May 16, 2003 | 12:15 PM
88 427 Camaro's Avatar
I used the Hurst swap kit from Jegs. Then had an old Chevelle drive shaft cut and balanced. No problems althought the torque arm bracket did require a little grinding.
Miles
Old May 16, 2003 | 01:44 PM
JeffT's Avatar
check here: http://www.spohn.net/index.cfm?fusea...t&productid=13
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
92_RS_305
Sep 8, 2015 07:47 PM
