Head Gasket?
Old Jun 4, 2003 | 10:20 AM
Kuruption562's Avatar
Head Gasket?
Was crackin.... Some foo in my city is sellin me a 1986 IROC-Z. It has a 305 TPI.... but theres one thing wrong with it, he said the head Gasket is broken. Im not too familiar with what that is but he took off the oil cap when he showed me the problem. Is that alot to fix? Cuz the body n **** is straight, Its T-TOP with flowmasters n ****. Black with the stock rims.
Holla.
Old Jun 5, 2003 | 12:00 AM
Nitromethane's Avatar
You need to remove the whole TPI setup (intake plenum, throttle body, distributor, intake manifold, runners, fuel rail), the accessory brackets (alternator, air pump, power steering pump, ac), remove the valve covers, remove the rocker arms, remove the pushrods, unbolt the cylinder heads, pull them off, remove the head gaskets, scrape the surfaces clean, put on new head gaskets, then put the heads back together, set the rocker arm valve lash, put the intake stuff back on, drop in the distributor, set the timing, start the car and voila. If you don't know anything about engines, I don't suggest attempting this without assistance from someone more knowledgable. It'll be kinda pricey to have someone else do it for ya, but call around.
Old Jun 5, 2003 | 06:15 PM
Thanks homie...well i talked to the guy last night and he said he took the car to the shop to get that fixed, its still in there today so hopefully Ill get it soon and im lookin foward on conversatin here bout my camaro and yalls.
Old Jun 6, 2003 | 12:46 PM
GMTONY55's Avatar
Be sure to have those heads checked.THey may be cracked.Alot more money
Old Jun 8, 2003 | 01:31 PM
aklim's Avatar
Sounds like a good time to get AFR 190 heads or 195 heads and a better intake system.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
