B&M shifter problem...
Old May 24, 2003 | 10:49 AM
IROC350's Avatar
i just installed the megashifter and can't get it to shift out of reverse/park. any suggestions as to what is causing this?? its all thats left to get my car back on the road!
Old May 24, 2003 | 11:52 AM
AndrewC's Avatar
are you pullin up on the line lock out to release it from park, the little T handle under the regular handle? this shifter locks into gears.
Old May 24, 2003 | 12:23 PM
IROC350's Avatar
ya, i know that...i'm pulling that handle and still nothing.
im pretty srue its cable related.
Old May 24, 2003 | 12:34 PM
Lungz's Avatar
quite honestly, I always have problems when I reinstall the shifter without following the isntructions, as soon as I go over the instructions a secodn time it works out, make sure that you did things almost exactly as the instructions indicated.
Old May 24, 2003 | 01:11 PM
IROC350's Avatar
well, therein lies the problem...i had installed by a buddy of mine. that's why its kinda hard "debugging" the problem.
Old May 24, 2003 | 03:15 PM
AndrewC's Avatar
Talking shifter
ok , well you have to adjust the cable while in 1st gear. loosen the cable, put the shifter into 1st, then adjust the tranny to 1st gear,and connect the cable, usually works everytime with no problems.
Old May 24, 2003 | 03:38 PM
IROC350's Avatar
wow, i never thought of that...i'll try it tomorrow and let you guys know the verdict!
Old May 24, 2003 | 03:51 PM
Lungz's Avatar
yeah and you have to make sure the "swivel" as tey call it is lined up and also make sure that the bracket is all the way against the shifter on the tranny and not on the bolt thread, and the swivel MUST be in the front hole in order to work, there were also some triggers you need to put on the console part of the shifter that I think may stop you from going out of reverse.
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
