tpi/ to blower carb?
i want to switch from the tpi settup i have and go with a blower carb instead, does an 1982 z28 have a smog pump, and do you act. need , in 1982 did they have a carb'd motor. i'm trying to see what i can stick in my car and pass emmisions
Contact Holley. They have versions of their Weiand/Holley 144 roots-style blower that are emissions legal. You will need at least a 4" cowl hood to fit it under. It will work with the stock compter-controlled QJet carb and distributor and ECM of that year.
Re: what i'm saying
Originally posted by crazyk1le
what i'm sayin is if they had somthing that was carb'd i can pass using a carb'd engine
also why not just run a centrifugal setup on your tpi? it will be a LOT easier to install, might be a bit cheaper, make the same or better hp and might get a tick or 2 better mpg.
i have an 87' but i can get an 82' the truth is i took the tpi apart and now i'm lost on how i'm gonna get it back togother also it's very expensive to do some real **** to these cars.
runners $400
intake$400
inj. $400
throttle body $400
wiring harness$400
cent. blower $3000
that alone equals $5000
roots blower$2,300
carb$600
total$2,900
really i'm just intimidated of the tpi ( putting it back together)
say i bought a wiring harness from howell eng. they sell a hotrod kit cleans up the wires anyways if i do with eveything will i be easier to put back together is there a book i can get to help me
runners $400
intake$400
inj. $400
throttle body $400
wiring harness$400
cent. blower $3000
roots blower$2,300
carb$600
total$2,900
RUENUF
Mar 13, 2016 03:37 PM
