running the 7004r without lock up
Old Feb 27, 2005 | 10:14 PM
Duke901's Avatar
I have a 27 spline 700r4 that is going behind a big block. The problem iam having is that iam not running the lock up, And all the converters I find for the 27 spline 700r4 use the lock up, so what will happen if I get a 3000 stall and not use the lock up feature.
Thanks Mike
Old Feb 28, 2005 | 12:47 AM
FruityOne's Avatar
Re: running the 7004r without lock up
You could possibly overheat and glaze the frictions if you do a long WOT run without a good cooler.
Why run without a lock-up? The benefits outweigh the disadvantages.
Old Feb 28, 2005 | 03:52 PM
JSkeet's Avatar
my TCC has been unplugged nearly 9 months, no issues yet.
Old Feb 28, 2005 | 04:12 PM
96m6lt1's Avatar
just be sure to have a big external cooler on that tranny!
Old Feb 28, 2005 | 05:14 PM
transxtreme's Avatar
Summit sells a lockup for use with a carb. Not a stock 700 i hope.
Old Feb 28, 2005 | 06:29 PM
FruityOne's Avatar
The problem with no lock up isn't when you are driving normally. But when you are on it hard for extended periods of time. Such as autocross, back to back drag racing, or road courses. Or just plain old highway blasts. Its heats up the transmission like crazy, a good external trans cooler is a must!
Old Feb 28, 2005 | 08:22 PM
Duke901's Avatar
Well i have no lock up because i took all my computer wiring out and i dont want to wire one up. So you think it should be alright if i just get a good cooler.
Old Mar 3, 2005 | 06:35 PM
Here is one from summit
http://store.summitracing.com/defaul...=egnsearch.asp
oldschool
Feb 9, 2016 09:21 PM
Rod Bender
Jan 3, 2015 03:15 PM
ro2207
Dec 4, 2014 06:18 PM
Jake77444
Jul 21, 2002 05:37 PM
