Roller rockers
Old Mar 16, 2005 | 08:09 PM
1987Z28's Avatar
Roller rockers
How much will roller rockers help. More importantly what will it help...i understand it will alow the motor rev up quicker...i also want to know if you think they are worth the investment.
Old Mar 16, 2005 | 08:21 PM
cc89formula's Avatar
Re: Roller rockers
Full roller 1.6:1 rockers should gain you about 15hp and lower oil temps a little. Less friction less heat, easier on the motor. IMO they are worth it.
Old Mar 16, 2005 | 08:41 PM
anthony714's Avatar
Re: Roller rockers
worth it depending on what kind of motor you got.if its bone stock dont bother,you ll gain some but never notice it
Old Mar 17, 2005 | 07:27 AM
teke184's Avatar
Re: Roller rockers
i think you would notice it on even a stock motor.
however...upgrading to 1.6 rockers from the stock 1.5 could max out your springs.
check what the max height is on the stock springs and determine the lift of the cam...then recalculate for the 1.6s..
if you wanted to go a little budget minded...there are some good roller TIP rockers in 1.6ratio on the market for 1/2 the cost of full roller
Old Mar 17, 2005 | 02:01 PM
1987Z28's Avatar
Re: Roller rockers
how do you do that...i will replacing my valve stem seals on sunday so what should i do to calculate this????
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
