vortec heads i need help
Old Mar 9, 2005 | 09:23 PM
"THEPROJECT" 85 Z28's Avatar
guys i really just want to kow what to do to them to get the most power there going on to a 383 and i need to know what all should be changed the springs valve size what to do
thankx
Old Mar 9, 2005 | 10:39 PM
zrs's Avatar
zrs
Re: vortec heads i need help
Remove press in studs and replace with screw in studs. Port and polish. What are the spec on the cam you will be using? If you will have high lift, you will need to do some vavle guide work to accept the high left and spring pocket as well. Recommended to use 1.6 rockers unless you are running a big cam.
dfarr67
Apr 10, 2015 07:44 PM
dawg irocz
Feb 10, 2015 10:33 AM
Lakebratt
Feb 5, 2015 07:55 PM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
