fuel pump relay
Old Mar 15, 2005 | 06:47 PM
chevyman502bb's Avatar
fuel pump relay
where is it? 88camaro sport coupe TBI305
Old Mar 15, 2005 | 06:50 PM
Kwiksilverz28's Avatar
Re: fuel pump relay
On firewall near master cylinder.
Old Mar 15, 2005 | 06:56 PM
Re: fuel pump relay
pictures? its dirty as **** under my hood and nothing is labeled
Old Mar 16, 2005 | 11:52 AM
Ben91RS's Avatar
Re: fuel pump relay
I'll have a picture up for you shorty.
The fuel pump relay is located on the driver's side firewall, in between the brake booster/master cylinder and the driver's side fender. It is held in place by a small black bracket that holds 2 relays side by side. The relays look like small black rectangular boxes. The one closest to the brake booster/master cylinder is the fuel pump relay (it should have a 5-wire connector) while the one closest to the driver's side fender is the coolant fan relay (4-wire connector).
Old Mar 16, 2005 | 03:20 PM
Ben91RS's Avatar
Re: fuel pump relay
Here you go, the little gray "boxes" are the relays.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
