Ok one more "annoying" question
Old Feb 28, 2005 | 08:16 PM
LoudmouthSS's Avatar
Ok.. I'm just curious to know what you guys think i've got as far as rwhp goes..I know i wanna upgrade to a holley stealth ram and some different headers, but other than that I may leave this motor alone if it makes good power..I found out the orig owner did a mild port job on the heads, so i may just do a bigger port job on the factory heads to "save" them. I'm on a budget here, so id like to save any money i can, and plus im not going to go too insane with this engine, after all, it is my daily driver.
My plans are to go with a new short block, send the heads out and see if they can be saved with a bigger port job, get a stealth ram and get different shorty headers..then basically reuse everything from the old motor that i can..So with that said, what do you think rwhp will be on the motor with these specs..
Comp Cams Roller Cam - 224I,230E @.50/
.513"I,.520"E
Comp Cams roller tipped rockers (1.52:1)
Comp Cams 1.437 dia duel valve springs
Comp Cams locks, retainers and 11/32 teflon seals
Holley Twin 58mm throttle body
Holley stealth ram
Valves cleaned & refaced
Heads resurfaced and machined to accept cam hardware
Port and polish job
Heddman 1 5/8" shorty headers with Y pipe ( was a 2 cat car converted to 1)
Catback exhaust
Underdrive pullies
K&N filters
MSD 8mm wires
Accel 300+ digital ignition
Hypertech Stage 2 chip
160 degree thermo, 176 degree on/166 degree off fan switch
3.73 gears
Old Mar 2, 2005 | 11:27 PM
V8Rumble's Avatar
Re: Ok one more "annoying" question
Hmmm. Taking a look at what you've written above there are two things that jump out at me:
* First, that looks (to me) like a really big cam for stock heads, whether they're ported or not. You might want to get a second (or fourth, or fifteenth) opinion on that...
(EDIT: I've heard a lot that you can frequently get a decent set of aftermarket heads for the cost of re-doing stock heads. Might be worth comparing some prices...)
* Second, I've heard very little good about Hypertech chips, I'd personally stay away from that brand. IIRC, all they do is throw in a little more timing advance, & bump the fuel curve a little - it's really generic.
That doesn't mean that you're stuck trying to burn your own PROM though, I've heard good things about a guy who will get your specs from you, burn one that's pretty close, & then work w/ you a little bit back & forth through the mail to get it dead-on. (I think it's $300 or so, & he'll burn the 1st 3 chips for that price.) Like I said, he's supposed to be real good, I just can't remember the name...
I don't know if it would be worth it for me to try to guess how much power you'd make, but if I had to pull a WAG outta my butt, I'd say 340 to 360 hp - limited by the cyl heads...
Good luck!
Old Mar 3, 2005 | 03:15 PM
yea i know its a big one lol, guy who did my car ( i bought it with all that stuff) said he was goin to put dart heads on it and upgrade to a holley stealth ram
And yea im gettting rid of that chip, its making the car run rich i think, but i do know its a pos..
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
