Speedo Gear coloring
Old Apr 11, 2005 | 11:11 AM
WhiteLightnin83's Avatar
i'm wondering if anyone knows what color the speedometer gear is in side the tranny for a 3.73 rear-end. i have a yellowish/tan one in there now and it must be for a stock 3.23 or something cuz its off by about 20 mph at 60... anyone know what color it is for a 3.73 gear ratio?
Old Apr 12, 2005 | 01:48 PM
Z28SORR's Avatar
Re: Speedo Gear coloring
Your friendly Chevy dealer parts guy. I May still have mine, I'll look tonight.
Old Apr 14, 2005 | 09:56 AM
Z28SORR's Avatar
There are two "types" large(older cars) diameter and small(newer ones). These are small diameter. The one for the 3:73 gear is red (21 tooth).
Old Apr 14, 2005 | 07:15 PM
Kwiksilverz28's Avatar
http://www.tciauto.com/tech_info/speedo_gears.htm This is how I got what gears to use. Had to change both. Needed a 15 tooth (grey) and a 44 tooth (dark grey) for my 88 GTA with 3.73's and a 700R4. Speedo is certifiable it is so close!
Old Apr 14, 2005 | 11:45 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
A 21 tooth red is for a T5, and it sounds like he's asking about an automatic.
Old Apr 15, 2005 | 12:02 AM
buzz12586's Avatar
I have a T-5 and I am switching from 3.08s to 3.42s, anyone know what speedo gears I will need.
Old Apr 15, 2005 | 10:25 AM
Z28SORR's Avatar
Yes it is. My mistake for assuming a 5 speed.
Old Apr 17, 2005 | 07:26 PM
Kevin91Z's Avatar
A 7 tooth purple drive gear (meaning you will need to pull the transmission to install it. You have a red 9 tooth now). And a 19 tooth driven gear. I dont remember its color.
Old Apr 18, 2005 | 11:23 AM
so what gear color combination do i need with my car? with 3.73 and a 400-turbo? this **** is a bit confusing to mix and match...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jubjub
Mar 19, 2015 10:23 AM
blac94Z
Feb 10, 2015 11:02 AM
Jul 4, 2005 05:00 PM
