87 brakes
Old Apr 15, 2005 | 02:57 AM
TigerZ's Avatar
87 brakes
got in an accident recently. destroyed my brakes. replaced pads and rotors. discovered calipers were shot - replaced and bled lines. brake pedal goes to floor easily with no resistance and takes forever to stop. rear drum brakes work fine. told it was a booster problem or master cylinder problem - replaced both, bled system. still same problem. when car is turned on and pedal pressed to the floor parking brake light comes on. any ideas???
Old Apr 15, 2005 | 11:38 AM
Marc 85Z28's Avatar
Re: 87 brakes
So you've basically replaced nearly every brake system component short of the lines and the rear drum setup?
1. Make sure the rear drums are adjusted properly.
2. Inspect the entire system thoroughly for hydraulic leaks.
3. Verify that you have the proper type of fluid, and that it's filled and completely bled. How are you bleeding it?
4. Verify all parts are correct. An incorrect master cylinder would cause this problem. A booster issue will not.
5. If you don't find anything wrong, take it to someone who knows what they're doing.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
