Turbo Info Needed
Old Apr 7, 2005 | 09:02 AM
Ragtop-87's Avatar
Turbo Info Needed
I am looking for an Turbo for an 87 Camaro w/305 any info would be helpful.
Old Apr 7, 2005 | 12:45 PM
Nitro's Avatar
Cool Re: Turbo Info Needed
The only Turbo Kits that I have found is these http://www.hawksthirdgenparts.com/turbos you might want to check it out since the LT1 parts will fit on your 305
Old Apr 7, 2005 | 08:17 PM
J'S Z's Avatar
You can also go over to www.thirdgen.org in their power adder forum the have a few threads on turbos
Old Apr 7, 2005 | 08:25 PM
stealthblack's Avatar
If youre a fabricator, and on a budget, you can get two turbos from 2.3L Ford motors [they are fairly common and cheap in junkyard or reman] flip a set of shorties upside down, tweak the tubes slightly,fab flanges,down pipes,inlet tubing,etc.An intercooler will cost you some $ but thats the only exp. piece.Then tuning[carb or FI].Thats the brief overview but there's youre homemade twin turbo kit for prob $1200 or so if you can weld.Not that ive done it but its a thought.
Old Apr 8, 2005 | 12:16 AM
iansane's Avatar
http://www.bbsdesigns.net/
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
blac94Z
Jan 22, 2015 11:19 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
