int. lights
Old Mar 6, 2005 | 09:08 PM
unvc92camarors's Avatar
int. lights
is the instrument panel supposed to light up when your parking lights/headlights are turned on?
the part that says "a/c, heat, etc."
mine isn't lit up and i can't remember if it's supposed to be or not
thanks
Old Mar 7, 2005 | 01:04 AM
zrs's Avatar
zrs
Re: int. lights
Yes it is. Are you sure the dimmer switch is not turned down? Try turn the light switch right to brighten and left to dim. If it is not working then your bulb may have burned out or wire has bad connection.
Old Mar 7, 2005 | 01:05 AM
White_96_SS's Avatar
Re: int. lights
yup, check the dimmer if not a fuse maybe or a short..
Old Mar 7, 2005 | 07:33 AM
Re: int. lights
definately not the dimmer
i wouldve noticed that my gauges weren't lit up either
thanks though, i'll check the fuse and hopefully that'll fix it
Old Mar 7, 2005 | 04:54 PM
Rice Killer87's Avatar
Re: int. lights
from what a remember,its only 1 bulb that lights up the AC/heater controls. take the plastic around them off,then pop off the 4 bolts that hold the heater controls to the mounting bracket and then you should be able to see the bulb.
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
simple
Aug 11, 2002 11:56 AM
simple
Aug 2, 2002 03:30 PM
