Hydrolic rollers?
Old Mar 15, 2005 | 07:55 AM
1987Z28's Avatar
Hydrolic rollers?
was a 87 iroc TPI, equiped with hydrolic rollers????
Old Mar 15, 2005 | 10:07 AM
krazzycowgirl's Avatar
Re: Hydrolic rollers?
I can second that one, after searching for a cam. Yes they did come with them.
Old Mar 15, 2005 | 10:17 AM
Camaro500's Avatar
Do you have to replace with a cam change?
Old Mar 15, 2005 | 10:47 AM
What the rockers??? It is suggested that you do, unless they are clean & rebuilt. The shop that is doing all my work suggested that we buy new ones since ours were 100% stock & were nasty looking.
Old Mar 15, 2005 | 01:41 PM
Camaro500's Avatar
Sorry I meant the roller lifters.
Old Mar 15, 2005 | 04:48 PM
Rice Killer87's Avatar
if your changing the cam and the lifters are original,then YES,install new ones w/ the new cam. NEVER use old lifters w/ a new cam.
you should also put on new valve springs w/ a new cam.
Old Mar 15, 2005 | 07:07 PM
TheGreatJ's Avatar
I have to argue that one. Roller lifters don't develop a wear pattern with the cam like flat tappet lifters do. It is perfectly safe to re-use your factory roller lifters with a new roller cam. It's generally a good idea to change springs, as the stockers aren't made to handle much lift and will float fairly easily.
With the older flat-tappet lifters, you DO have to replace them when you change the cam.
Old Mar 15, 2005 | 09:13 PM
DevilsAddvocate's Avatar
agreed
Old Mar 16, 2005 | 02:36 PM
anthony714's Avatar
double agree...roller cams are ground flat,so wear doesnt matter like a hydralic cam.if the roller surface and bearings ok you can reuse them,just clean them up real good,heck take them apart and reclean them,folk rebuild them all the time
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
