TA Girdle
Old Mar 10, 2005 | 12:35 PM
klumb15's Avatar
TA Girdle
are these things worth it? i think they are like 150-200 bucks, but they say they increase the fluid volume 1 pint and strenghthen the rearend quite a bit because it has bolts that get torqued down on the end caps to keep them from walking around in there....but i don't have a lot of extra ching to throw around, because my car is in pieces, and its in the process of going back together, do you think as long as i have the rearend out and changed all the parts in it, i should put a TA girdle on it as well? i already have like $900 into my rearend, so if you guys say i don't need it, then i won't get it...do you think its a neccisity?
Old Mar 10, 2005 | 12:38 PM
Tru2Chevy's Avatar
Re: TA Girdle
The girdle is a good investment if you plan on throwing any real power at a 10 bolt. You shouldn't be paying $200 for one though....they are usually around $120.
- Justin
Old Mar 10, 2005 | 05:26 PM
Marc 85Z28's Avatar
Re: TA Girdle
Yes, very highly recommended. Remember no more than 5 ft/lbs on those main cap braces! And while you're at it, weld the axle tubes to the housing.
Old Mar 10, 2005 | 08:23 PM
klumb15's Avatar
Re: TA Girdle
alright, where can i pick one up for 120? as far as welding goes, just weld a bead right where the axle tube comes out of the pumpkin right? any other places i should weld to stiffen her up a bit?
Old Mar 10, 2005 | 08:38 PM
Kwiksilverz28's Avatar
Re: TA Girdle
Check out http://www.thirdgen.org/newdesign/te...nguprear.shtml . Very good article. I am finishing up building a 10 bolt as described for my GTA.
klumb15's Avatar
Re: TA Girdle
it seems most places have the TA girdles for like 154 seem sto be the magic number...i found this one, made by MAC...http://fasttoys.net/shop/product_inf...oducts_id=1223 which is $128.00, i believe it is the same thing, just different name...do you guys know any sites with better prices?
Old Mar 11, 2005 | 10:10 AM
klumb15's Avatar
Re: TA Girdle
anybody know where i can get it cheaper? i need to order it today or saturday...need answer quick...
96SilverRam
Nov 20, 2016 11:19 AM
FryedClutch
Sep 1, 2015 08:24 AM
R@mpage
Apr 20, 2015 10:02 AM
stonedchihuahua
Jan 1, 2003 08:41 AM
