electric water pump question
Old Apr 5, 2005 | 10:23 PM
Nick's WS6's Avatar
I have an electric water pump on its own switch which just turns it on and off. and then I have an electric fan on its own separate switch. im wondering what I can do to get this connected to the temp to automatically turn on. This was a engine swap into a 75 porsche 914 so its a bit unique.
Old Apr 5, 2005 | 11:04 PM
markinkc69z's Avatar
Re: electric water pump question
I suggest leaving the wp on a switch for quick warmup and putting the fan on a hypertech or painless fan temp switch with a relay. If the pump were to shut off during operation hotspots could quickly develop in the heads and lead to detonation.
Old Apr 6, 2005 | 12:21 AM
IROC-T's Avatar
There is a switch called a "Tic Toc" switch used in racing that switches the water pump off and on for better cooling(or something like that)I think you may find them in a Jegs cataloge if I'm not mistaken. Might be what you need.
Old Apr 6, 2005 | 01:33 PM
anthony714's Avatar
id suggest junking the electric water pump,you only gain around 4 hp and for the lack or reliability they have for street use i wouldnt use it
Old Apr 6, 2005 | 05:01 PM
Nick's WS6's Avatar
ok here is why i have an electric pump. the car was originally setup with an air cooled 4 cylinder angine, so now there is a water cooled v8 mounted in the rear. the water lines to the radiator run the full length of the car to the front where the radiator is. so the problem was the engine would rev too fast and blow the hoses off the fittings, we fixed that problem and the hoses were bursting instead. with the electric pump the problem is no more. but now its just hooked up to an on off switch and not temprature controlled.
I found something recently which I think is just what i need. it's a Moroso Thermostatic water pump switch.
Old Apr 6, 2005 | 10:07 PM
anthony714's Avatar
ok im assuming here and going out on a ledge that this isnt a camaro you have????also im assuming you were bursting hoses cause im guesing they were too long?if that was the case did you try a solid hose between the front and rear of car,maybe pvc or a copper pipe?just use the rubber to connect the pipe to engine and or radiator
Old Apr 7, 2005 | 01:08 AM
IROC-T's Avatar
I don't think your original problem was the stock pump pumping to much,but it had to much back pressure. I think what was needed was an auxsilory(sp?)pump on the return side of the radiator. The stock pump is not intended to move that much water ,that far. With a aux pump,stainless tubing, and Earls solid radiator hose your problem should go away.
HectorM52
Jul 30, 2017 11:46 AM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
