stock fuel pressure for 88 L98
Old Apr 4, 2005 | 03:49 PM
89305rs's Avatar
What is stock fuel pressure on a 1988 L98 iroc? Please specify vaccum line on or off of the regulator. I would like a static reading though.
Old Apr 4, 2005 | 03:52 PM
Z28SORR's Avatar
Re: stock fuel pressure for 88 L98
You set it with the vacuum line off. (Adjustable reg.) But I can't remember the exact pressure.
Old Apr 4, 2005 | 04:56 PM
87DJP2001's Avatar
Wi
With the vaccum lines on:
Key on engine not running....36/38 PSI
engine running at idle .....38/40 PS
running at med thottle ......40/43 PSI
This about average for a stock 350
Old Apr 5, 2005 | 08:29 AM
89305rs's Avatar
Thanks i checked it last night and it was right around those numbers!! Thanks again-Joe
Old Apr 7, 2005 | 12:23 AM
Nitro's Avatar
Cool Re: stock fuel pressure for 88 L98
If I remember right the Fuel Pressure for a IROC Z TPI is 38-40 PSI
Old Apr 7, 2005 | 12:58 AM
raul.garcia's Avatar
1986-to-1990 5.7L/350 MPFI specifications
With full vacuum applied to the regulator (idle):
Use 38psi which is the average of 30.5 and 44psi.
With no vacuum applied to the regulator (WOT):
Use 43psi which is the average of 40.5 and 47psi.
Then you can tweak it from there.
DirtyDaveW
Dec 1, 2016 05:37 PM
Cam's maro
Jan 30, 2015 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
