S-m-o-k-e
Old Mar 9, 2005 | 12:10 PM
1987Z28's Avatar
S-m-o-k-e
I have a 87 iroc 350 tpi when i start the car a puff of smoke comes out of the tail pipes, someone said this was my seals on the valves that were leaking...they gave me a diagram on what to do and how to do it....i would appreciate it if someone would put that diagram back on, the file i saved it to was erased and i wanted to get this done before i bring it out of storage, thanks for your time....
Old Mar 9, 2005 | 04:20 PM
87DJP2001's Avatar
Re: S-m-o-k-e
Valve stem seals. common occurance on SBC engines with over 50K on them.
Old Mar 10, 2005 | 10:23 AM
1987Z28's Avatar
Re: S-m-o-k-e
can anyone else send out a diagram of the work that has to be done....thanks there was a nice pic on here about 2-3 months again
Old Mar 10, 2005 | 05:49 PM
Rice Killer87's Avatar
Re: S-m-o-k-e
heres a not too detailed list of what needs to be done:
-remove valve cover/(s)
-remove rocker arms
-buy the fitting that screws into the spark plug hole to inject compressed air into the CC to keep the valves from falling down.
-inject CC's w/ ain
-use valve spring compressor to remove the spring and retainers
-pull off the old valve seal...install a new one
-put valve spring back on/install retainers.
-after your finished you must adjust the rocker arms
you can only do one cylinder at a time,which means,2 springs at a time.
ive done this before,its not very hard if your mechanically inclinded,but its just time consuming.
Old Mar 10, 2005 | 06:57 PM
1987Z28's Avatar
Re: S-m-o-k-e
Thanks for the help....what are you looking at time wise to do this? and i am mechanically inclinded, but i have never done anything with heads, how do you adjust the rockers? thanks again
Old Mar 15, 2005 | 03:25 PM
1987Z28's Avatar
Re: S-m-o-k-e
Whats Shot Is The Valve Stem O Ring On Top????right?????
Old Mar 15, 2005 | 04:45 PM
Re: S-m-o-k-e
whats shot is the round seal thats about 1/2 inch to 3/4 of an inch tall,wraps around valve stem right where it comes through the valve guide on the cylinder head.
