TPI From LB9 on a L03
Old Apr 21, 2005 | 08:03 PM
89_Irocz's Avatar
I know a TPI off of a 305 LB9 will fit on a 305 LO3. What I need to know is how it will profrom? The LO3 with the TBI has 170hp. And the LB9 305tpi in my 89 iroc-z is 195hp. The C.R. on both are 9.3:1 Would the HP be 195 are closer to 170? If you know anyone that has done this or if you have any info please help. Thanks
Old Apr 22, 2005 | 07:42 PM
Black305RS's Avatar
Re: TPI From LB9 on a L03
it would be about the same as the lb9's power but possibly a little less because i beleive the cams are different. ill be finding out in about a month i just got the tpi unit and after a few missing arts are located ill be installing it.
Old Apr 22, 2005 | 08:33 PM
'92 RS Hybrid-Z28's Avatar
I installed the TPI intake and computer on my 92 RS 5-speed, with no other changes. It made 17 HP and 70 TQ more at the wheels. It went from 158 HP to 175 HP, and 220 TQ to 290 TQ. I later installed a TPI cam and it went up to 187 HP at the same 290 TQ.
Remember you have to change the computer and wiring harness, too.
Old Apr 23, 2005 | 09:23 PM
89_Irocz's Avatar
Thanx Guys, I'm getting a LB9 from PowerPro Engines for $1,535 with a 5 years 100,00 mile warranty.
Old Apr 25, 2005 | 11:50 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Uhm... if you're pulling out the engine, why put back in a 305?
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
SnkSknrZ28
Jun 20, 2002 01:33 AM
