350 bottom end question
Old Apr 12, 2005 | 04:11 PM
91-Z28-L98's Avatar
How much hp and torque can the stock bottom end of a sbc 350 take? When finished with my build I want to have about 350 - 400 hp to the wheels and I want to know if I need a steel crank and rods or if I can get away with machining the stock cast ones. Thanks.
Old Apr 12, 2005 | 05:28 PM
Rice Killer87's Avatar
Re: 350 bottom end question
How are you gonna make the power? Heads/Cam...nitrous,turbo,supercharger...?
If your just using heads/cam and an intake the stock bottom end should be fine as long as your not spinning it to 6500+.
If you have the funds and its already outta the car,builind the bottom end isnt a bad idea...but thats of course if the funds are there...and most the time thats not the case unfortunately.
hope this helps
Old Apr 12, 2005 | 11:52 PM
transambill's Avatar
A stock L98 bottom end is good to 400hp.
Old Apr 13, 2005 | 06:23 AM
91-Z28-L98's Avatar
400hp to the wheels or to the crank itself?
Old Apr 13, 2005 | 10:09 AM
To the crank.
Old Apr 13, 2005 | 11:54 AM
Marc 85Z28's Avatar
Many would disagree. There are numerous stock bottom end L98s pushing the 500HP mark. Keep extended use RPMs below 6000. The occassional 6500RPM blast shouldn't hurt much. ARP rod bolts would help a bit, and still be considered a stock bottom end.
Chris Anderson
Jan 27, 2015 08:30 AM
sscott
Jan 17, 2015 04:30 PM
Killer94z
Jan 13, 2015 12:06 PM
ChrisFrez
Dec 28, 2014 02:25 PM
Hurin
Dec 13, 2014 07:38 PM
