Swap Help
Old Mar 15, 2005 | 01:26 AM
Camarostud3's Avatar
Swap Help
I have 91 Camaro currently with a v6 in it but I'm swapping it out with a v8. I also want to replace the stock gauges at the same time with AutoMeters or some other aftermarket. Is this possible? I was planning on using the Covan gauge cluster but just noticed it only goes up to 1989. Any help/suggestion would be greatly appreciated. Thanks!
CamaroStud3
91 Hugger Orange Camaro RS
Old Mar 15, 2005 | 05:43 AM
thezisking's Avatar
Re: Swap Help
I think the biggest problem with the gauges is that in 1990 (when GM went to your style dash) the speedometer was electronic instead of mechanical. I'm sure they make aftermarket guages for your car, but I sure there expensive. My buddy has a 79 Z28 and he wanted me to call Summit to see how much a full set of Autometer guages were.....$750!!!!!! OUCH!
Old Mar 17, 2005 | 10:04 AM
Tru2Chevy's Avatar
Re: Swap Help
Are you going to to a carbed v8? If so, you can use the Coven panel and just run everything yourself (grabbing a mechanical sending unit and cable from a junkyard is pretty simple)
- Justin
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
