how do you adjust rockers
Old Mar 13, 2005 | 12:22 AM
1987Z28's Avatar
i want to replace my valve spring seals, i was wondering how you adjust the rockers when you are done?....
Old Mar 13, 2005 | 09:43 AM
Formula350ks's Avatar
Re: how do you adjust rockers
If you are doing one at a time you will tighten the rocker down untill there is no lash in the pushrod then go one more turn. (thats what the chilton manual states). If you have them all off at once then there is a sequence you will need to follow starting with the engine at TDC and tightening this one and that one and then turn it 180 degrees and tighten the rest. If you don't have a manual of some sort I suggest getting one.
Old Mar 14, 2005 | 01:30 PM
Anniversary-Z-man's Avatar
If they're all off....you must first bring the respective cylinder to TDC, then tighten the rocker nut till there's no lash on the pushrod, then one HALF turn more and you're set. Keep repeating til you've done all 16 rockers on all 8 cylinders.
- Joel
Old Mar 14, 2005 | 02:40 PM
1987Z28's Avatar
i would take one off at a time...i would put compressed air into the motor inorder to keep the valves up...then replace the valve stem seals...i would then need to adjust the rockers...i hope this wouldnt change the steps in adjusting the rockers....how much P.S.I. should i put into the cylinder, inorder to keep up the valves???
Old Mar 14, 2005 | 06:08 PM
If you do one at a time like you plan to then you will already have that cyl at TDC when you replace the seal. So just adjust untill there is no lash and either half or one turn most people say half but my chilton said a full. You can decide that then move to the next one. You will not need to go in any certain sequence if you are doing one at a time. The hose that I have recomends around 90 psi to hold the valve up.
Old Mar 14, 2005 | 06:13 PM
1987Z28's Avatar
Old Mar 14, 2005 | 07:18 PM
dj haf's Avatar
is it better to do it 1/4 turn past zero lash or 1/2 turn if you're running hydrolic roller lifters?
Old Mar 15, 2005 | 12:25 AM
92RS305#2's Avatar
i remember looking on alldata a while ago and it said to adjust the rocker arms in my 305 with the engine running...
Old Mar 15, 2005 | 11:10 AM
I have done that before and it seems to work fine but you'll have a mess unless you get the oil hole plugs.
Old Mar 15, 2005 | 06:53 PM
92RS305#2's Avatar
oh okay, i was just wondering which was the manufacturer's procedure and which is more realistic?
Old Mar 16, 2005 | 05:07 PM
mrr23's Avatar
http://www.fl-thirdgen.org/rockerswap.html wonderful tech article i did.
Old Mar 16, 2005 | 05:49 PM
Ben91RS's Avatar
Yep, either way will work just fine.
Just for what it's worth, I set valve lash (just like how it was suggested earlier) with the engine out of the car when I rebuilt it in Feb. 2004, and I haven't had to touch them since. I know that's not amazing to most people, but it is to me.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
