305 TPI put on a 350
Old Apr 14, 2005 | 09:53 PM
WinkleTheMoose's Avatar
Can, I switch my tpi to a 350?
Old Apr 14, 2005 | 11:43 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: 305 TPI put on a 350
First, do a search on this forum and read all the other questions and answers about this topic.
Second, yes you can, but remember a 305 TPI uses 19lbs injectors and a 350 uses 22lbs. You should get 22lbs injectors, and get yourself the right computer chip for your new combo.
Old Apr 15, 2005 | 09:19 AM
89385formula's Avatar
The knock sensors are different as well, so If you do do this swap be sure to change that too.
Old Apr 15, 2005 | 12:05 PM
5-7's Avatar
5-7
let's not forget that TPI was designed to flow just right on a 305. It chokes the life out of a 350. If the engine where going in a truck used for TPI, that's about the only reason to run TPI. Otherwise, ebay it, and get yourself a Holley Stealth Ram. They are $450 for the manifold, plenum, and fuel rails. Also, just bypass the knock sensor. It doesn't do good for anyone lol
Old Apr 15, 2005 | 01:06 PM
iansane's Avatar
No....Just....No.
The TPI setups between 350/305 are the exact same except for injectors and chip. No reason it'd "choke the life out of a 350" and flow just right on a 305. The tpi chokes off on any engine. It just doesn't flow well above 4.5K.
Why would you ever bypass the sensor? And why is it supposedly different? Part numbers are the same.
Old Apr 15, 2005 | 01:11 PM
Runin2Nite's Avatar
i'm doin a simaila swap. wut size inj do u guys recomend for a not so stock 350 or 355.
Old Apr 15, 2005 | 01:20 PM
WS Sick's Avatar
I stuck a mild 350 into my 86 T/A that originally had a 305 TPI changed nothing but the capacity of the engine in the program. Runs fine.
Old Apr 15, 2005 | 02:24 PM
iansane's Avatar
That's a really hard question to answer without more info on what the combo is. If whatever injectors you're using are going static, then they're too small.
Old Apr 15, 2005 | 10:05 PM
iansane's Avatar
Originally Posted by robvas
No, the TPI only flows X amount of air. Which is about what a 350 will consume at 4500 rpm. The 305 consumes less air and turns more RPM
Why not go with a stealthram or LT1 intake setup??
So you're saying a 305 won't choke at 4500 because it's sucking that much less air?
I'm not arguing that the TPI is better or even close to the HSR or comparable intakes. (Hell, I'm using the HSR right now and I love it).
Old Apr 16, 2005 | 10:24 AM
stanghunter211's Avatar
TPI was originally designed for the 305. It was sketchy back in the 80's as to whether or not GM was gonna put a 5.7L back in the camaro and they were looking for a smaller cube alternative. That's the only reason the 305 got any high-performance technology at all. But it should run just fine on a any small block. All depends on what you wanna do with the setup. Everyone knows you're gonna hit a roadblock with TPI as far as highend hp. They are really torque setups.
Will
Old Apr 16, 2005 | 08:29 PM
iansane's Avatar
Thanks for the obvious blanket statement.
You're saying that the 305 ISN'T going to choke at 4500 with the tpi. That's just blatently not true. What makes it use more air is moreso the cam and heads than cubes.
Old Apr 17, 2005 | 12:14 PM
iansane's Avatar
I've owned three over the last few years. An 87, an 85 and a 91. Must be cause they're firebirds or something
If by "they keep pulling after 4500" you mean "they pull to 4600" then yeah sure I guess you're right. Otherwise all three of mine have just stopped reving after that.
Old Apr 17, 2005 | 12:21 PM
iansane's Avatar
This is retarded. WAY off topic. To the original poster: Yes, you can use the tpi. You should also use with it the 22lb/hr injectors and at least a stock 350 burn as a baseline.
Is the engine a stock 350 or some other concotion? If it's even a mildly built engine you'll do better with a carb or some aftermarket tpi based induction system. The cheapest of which being the Holley Stealth Ram. To get it to run *best* you'll new a custom burn on the chip. Depending on how radical it is it'll still be drivable on the stock tune though.
Old Apr 17, 2005 | 06:13 PM
MY91Y84's Avatar
insane;
maybe your used to the peanut cammed auto 305's...i guess youve never driven a G92 305 with the 5 speed and 3.42 gears...
mine ran 14.4 with 36,000 and all the factory stuff...it ran its fastest when revved to 5,500-5,600...i know becasue i tried it at 4,800 5,200 and 5,600...
with a muffler a K&N filter and the egr walls ground down it ran 14.12@96..only the 3.23 geared L98's could touch it...
TPI was designed for the 305 and it would run really well..but you had to have the L98 cam T5 and 3.42 gears to get anywere...
the autos and non G92 LB9's were slow...which i guess is what youve driven...drive a G92 car and youll change your mind.
Old Apr 18, 2005 | 02:49 AM
iansane's Avatar
Originally Posted by MY91Y84
insane;
The 85 didn't have a peanut cam. Those cam with a cam identical to the early l98's. It was an auto however. The 87 was a non-g92 5 speed and the 91 was a g92 5 speed. Sounds like you know my cars pretty well though
Stock for stock they all are horrible for revving, period.
Like I said, this is retarded.
Ditch the TPI and go HSR. Can be done for not much more than a TPI swap.
